Killer dowel pin question
Old May 2, 2011 | 01:28 PM
SDT's Avatar
SDT
Default Killer dowel pin question
Hey all. Was on line this morning looking for valve lash specs and ran across some KDP info. Well my truck in a 97 and not wanting to deal with a failure of that type, I ran out and got gaskets and so on, tore the cover off and found my dowel a little past the casting. Pic included. Question is, is it ok to tap it back flush with the casting before I bolt in the retaining tab and is flush far enough in? Thanks!
Old May 2, 2011 | 01:33 PM
redneck_ram's Avatar
redneck_ram
do you have a cummins? if so, hit up the cummins section of the forum, we are gasser guys. but from what i know its quite common for them to work themselves out, and it is safe to drive it back in.
Old May 2, 2011 | 01:36 PM
SDT's Avatar
SDT
Oops, sorry! I thought I was in the right spot! How do I delete this post, can't seem to find where to do it anywhere?
Old May 2, 2011 | 02:04 PM
EndIsNear's Avatar
EndIsNear
I wouldn't worry about deleting it. A mod will most likely fix it.
Old May 2, 2011 | 02:38 PM
dodgeram07's Avatar
dodgeram07
Old May 3, 2011 | 01:41 PM
SDT's Avatar
SDT
Thanks dodgeram07, apparently the diesel guys on this forum don't want to reply as I reposted this in the Cummins section.
Appreciate the links!
SDT
Old May 3, 2011 | 04:23 PM
AFIN's Avatar
AFIN
Another good site I used when I had my Cummins was the "Turbo Diesel Register".
