Gasket Cement
Old May 3, 2011 | 07:04 PM
jpsycoboy5's Avatar
jpsycoboy5
Originally Posted by tweeker909
FELPRO Part # : MS95392 is the cork set used up to 97.......Part # : MS95392-1 is the updated rubber/metal core end seals used on 98-up. MS95292-1 can be used on 97-older. Little ULTRA BLACK RTV in all four corners.
Thanks for the help i'll go out and get that and hopefully have the truck all back together by morning
Old May 3, 2011 | 07:11 PM
tweeker909's Avatar
tweeker909
YW......Going to need some install pic's n such. KEGGER MOD why you have it apart?
Old May 3, 2011 | 07:17 PM
jpsycoboy5's Avatar
jpsycoboy5
I had the original engine apart because the #8 cyl had 40 psi of compression the piston ring had snapped and put a deep gouge in the cylinder. I got another 318 and have since been swaping motors, plenum, kegger mod, etc. I hoped that it was just the heads on the old motor but it wasn't.
