Suspension arm bushings/Tranny shift points
wonder steering? ...Do you mean steering wander? If so thier are a number of things to check....I just went through this. best this to do is have someone steer back and forth while your under the front look carefully at the pitman arm and other components for side to side movement and slop..therer is a bracket to remove sector shaft play / wobble at the pitman arm location and an adjustment to remove play in the steering box...also check you steering shaft for slop from end to end... If you use the search function and type "steering" you will find all the answers your looking for much faster.
go grab a rock from your garden if you need something to hold open your chiltons manual...Thats about the only use i have found for my tb spacer...or tapping it for nitrous
You're looking for control arm bushings. Aftermarket ones are cheaper than stock replacements.
http://www.topguncustomz.com/Store/G...view=250118353
You'd have to call and ask cause it says 00-01 but these are in my 97 but I've got skyjacker control arms. They should fit though.
ENS-5-3120G-black
ENS-5-3120R-red
