Pass. window wont go up
Old May 4, 2011 | 05:11 PM
calumetbud's Avatar
calumetbud
Default Pass. window wont go up
My passenger window wont go back up,it went down fine. But wont go up..
Just replaced the switch...any ideas..Thanks
Old May 4, 2011 | 05:28 PM
have a look at the wiring.
Old May 4, 2011 | 05:44 PM
calumetbud's Avatar
calumetbud
In the passenger door...?
Old May 4, 2011 | 07:25 PM
94Beater's Avatar
94Beater
Open the door panel and remove window motor with gear.
Try lifting the whole glass and see if it binds in the track - this could be a cause for your window not to come up.
Second, once you have the motor separated from the window assembly try the switch and see if the motor moves. if it does not then this is your issue - just replace it.
I can only think of 2 things that could be wrong (since you already replace the switch)
Either window regulator - window lifting mechanism or, the motor itself.
Hope this helps
Old May 4, 2011 | 08:04 PM
calumetbud's Avatar
calumetbud
very helpful,thank you very much. If not mistaken i have to replace the motor and regulator together?..Thank you
Old May 5, 2011 | 12:01 PM
calumetbud's Avatar
calumetbud
ok guys I put in a new regulator and motor,when i hit the switch it wont go up,it will still go down but not up....another thing,the drivers side door switch does not work with the pass. door either,dont know if that has anything to do with it or not thought i would add that in there..
