your opinion please
Old May 14, 2011 | 01:43 AM
STORMIN503's Avatar
STORMIN503
Default a lill more
SO.. My VIN. brought up this trim level... LT HD Reg. Cab 8-ft. Bed 4WD .. weird?? and it has a 5 leif pack on the rear with 3-1/4in blocks.. the front is all spring but once I put the engine in I think I'm gonna need 2-1/2in spacers to level it out. Its raked now with no engine in it.. is that common for the rear...??. I had a 1997 1500 4x4 that sat about 3 to 4in lower than this one.
Old May 14, 2011 | 05:29 PM
STORMIN503's Avatar
STORMIN503
Heres the build sheet..
Thank you for contacting the Ram Customer Assistance Center regarding
your 1995 Ram 2500.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AJKP Convenience Group
AJPP Power Convenience Group
APCA Center Band Two Tone Paint
ASPP SLT Decor Group
AWK Travel Convenience Group
BANP 120 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKBS Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUNP Overhead Console
CUVP Behind Seat Modular Storage System
CUYP Storage Tray
DGB All 4-Speed Automatic Transmissions
DGRS 4-Spd. Automatic 46RH Transmission
DHAS Lock-Up Torque Converter
DHHS Shift-on-the-Fly, 241 Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRGS Corporate 9.25 HD Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNKP Rear View Auto Dim Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPS Power 6-Way Driver Seat
JRDP Power Driver Seat
K17P STRIPE/BADGE/MOLDING
LAAP Ignition Time Delay Lamp
LAGP Warning Chime
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MPFP Journey Badge
MWDP Removable Tailgate w/Caliper Latches
MXB Front Air Dam
MXCP Front Bumper Sight Shields
NAAS Federal Emissions
NBKS EVAP Control System
NFVS 35 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PCHA Brilliant Blue Pearl Coat
QACA Silver Star Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RAY AM/FM Cassette Radio w/Equalizer
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBB Full Size Spare Tire
TBMP Tire Carrier Winch
TWPS LT225/75R16D BSW All Season Tires
TZHP Michelin Brand Tires
WDCP 16X6.5 Chrome Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email and have a great wwekend.
Sincerely,
Ralph
Customer Service Representative
Old May 14, 2011 | 05:45 PM
The 3/4 ton's sat a little higher than their half-ton brethren, so the bigger rear blocks aren't really a surprise. You have the light duty 3/4 ton though, with the same axles as a 1500, just, slightly meaner springs, and eight lug hubs.
