"Homemade" shackle flip with pictures
Old May 8, 2011 | 06:37 PM
sk8erdude's Avatar
sk8erdude
Default "Homemade" shackle flip with pictures
ive never seen anyone do this, maybe there is a reason for that. but this was stupid simple to do and me and a buddy did it in a hour.
cut the rivets off with the torch
flipped the shackle up, didnt even take it off
bolted it back in the lower holes on the frame/ upper holes in the bracket
and i can use the upper holes in the frame to drill new upper holes for the bracket. i only have 2 bolts in it right now. it gave me somewhere between 1-1.5'' of lift which i thought was good for no money and not much time to do it.
Old May 8, 2011 | 07:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Thats cool. Several posts about it.
I got custom made brackets to give me the most out the swap. It puts the shackle mounting hole below the frame rail insted of near the top of the frame rail like using the stock bracket. It gave me 3.25in lift, but moved the axle forward 1in. So for yours it may move it .5-1in. Your driveshaft should have enough play to compensate. https://dodgeforum.com/forum/1st-gen...with-pics.html
Here is one member who did the same style swap you did.
Old Nov 16, 2011 | 09:30 PM
EvanBoothe123's Avatar
EvanBoothe123
Lovin that fork lift lmao.
Old Nov 16, 2011 | 09:36 PM
biggreen2500's Avatar
biggreen2500
were did you get your custom made brackets? did you order them on line or had someone you know build them
Old Nov 16, 2011 | 09:44 PM
kejobe's Avatar
kejobe
Top Gun has them roughly 4 inch lift: http://www.topguncustomz.com/Store/G...view=260852537
Old Nov 16, 2011 | 10:45 PM
biggreen2500
yeah forget that crap... way to much lol... for 1000 bucks i can get a complete 6in lift
Old Nov 17, 2011 | 12:10 AM
99dodge318's Avatar
99dodge318
But that complete kit will most likely come with rear blocks to lift the rear.
And the 2nd gen rams have a factory 3" block on the 4x4's. Or you could upgrade for more $$$ to a aal but those usually give you a rough ride.
What these guys are doing is cheap and easy depending on your skills and tools.
Speakin of tools, I wish that I had a fork lift around to help me lift ****! lol
Old Nov 17, 2011 | 12:12 AM
biggreen2500
yeah blocks aren't bad at all.... i have 2 4in blocks stacked on my wheeler... the lift i found comes with 5.5in blocks and 1.5ui add a leafs......
ride rough? its a truck i drive they aren't suppose to drive like a car
99dodge318's Avatar
99dodge318
Sk8erdude did you also chop off your exhaust while you were back there? Looks like its dumped right above the rear axle.
Old Nov 17, 2011 | 12:27 AM
pcfixerpro's Avatar
pcfixerpro
It does look that way. Mine is chopped quite a good ways before the axle. Give a nice rumble inside the cab. I paid for the headers/ high flow cat / super 44 muffler... I wanna hear it!!
