Hard Chugging and Check engine Light is flashing on and off
Old May 8, 2011 | 10:37 PM
Jakob_ Eekhoff's Avatar
Jakob_ Eekhoff
Default Hard Chugging and Check engine Light is flashing on and off
Hi guys, im new to this forum so I will try and give this a shot, I have a 2001 Ram 1500 5.9. And my issue started like this, Friday night my drivers side header gasket blew out, so i spent this weekend getting a new one put in. While i was fighting with header bolts i ended up removing all the plug wires on that side of the engine. The plug wires didnt want to come loose very easily so there was a fair amount of pulling on the boots and base of the wire. Once i got everything back together and hooked up and the truck fired and idled fine, but once i got down the road the truck would chug and shake extreamly hard when i was on the throttle. It would get worse the faster i went. then the Check engine light would flash on and of if i got over 2k rpm. My truck has never done that this before and the engine light was never on. I just had my tranny built in the middle of the week. Any help is greatly appreciated
Old May 8, 2011 | 10:40 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Flashing CE is indicative of a random misfire. It sounds like one or more of the plug wires was damaged if excess force was required on the boots. It would be a good idea to replace the plug wires and route them as per the TSB that can be found in the FAQ area. Also, take care to install di-electric grease on the top tips of each plug before installing the appropriate plug wire.
Old May 8, 2011 | 10:42 PM
matty675's Avatar
matty675
+1, misfire no doubt. damaged plugs and/or wires
Old May 8, 2011 | 10:53 PM
Jakob_ Eekhoff
thanks guys, that is kinda what i figured, ill have to buy some new plug wires and plugs tomorrow after work and change them out, any suggestions on what brands and should purchase?
Old May 8, 2011 | 11:08 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Stick with the stock Champion plugs and make sure you gap them. Do not buy into this BS that plugs come pre-gapped. That's impossible.
Old May 9, 2011 | 12:43 AM
97tn4x4's Avatar
97tn4x4
Did you make sure you got the plug wires back to the correct plug?
Old May 9, 2011 | 02:38 AM
jasonw's Avatar
jasonw
Site Moderator
For plug wires, if you don't want to order something, O'Reilly's nicer BWD brand of wires are decent. Thats what I plan on using when I do mine next.
