Ac drain
Old May 10, 2011 | 04:45 AM
97tn4x4's Avatar
97tn4x4
Default Ac drain
So I noticed the other day with my air on I have no water dripping underneath the my truck. Pull the carpet back and bam water all in the floorboard. What exactly do I need to do to fix this?
Old May 10, 2011 | 01:11 PM
hydrashocker's Avatar
hydrashocker
There is a tube that drains the condenser box behind the passenger side exhaust manifold on the body (buy where the passenger places their feet) but in the engine bay. It's hard to see back in there. Most likely there is a blockage not allowing the condensation to roll out. Get a hanger or whatever and push it up in there to try to break it loose, but be careful.
Old May 10, 2011 | 06:32 PM
dhvaughan's Avatar
dhvaughan
drain tube exits the firewall under the pcm. its a little tube about 3/8 inch in diameter, and sticks out about 1/2 or less. sort of hard to see behind the AC stuff.
poke it out a thin wire with a little bend in the end. its likely clogged up with mildew.
Old May 10, 2011 | 10:06 PM
97tn4x4's Avatar
97tn4x4
Thanks I'll give it a try tomorrow if I get my truck back
