Electrical Cutoff at Start
Old May 10, 2011 | 09:01 AM
CanadianBrewer's Avatar
CanadianBrewer
Default Electrical Cutoff at Start
Hello.
I am looking for some help with my 98 Ram 1500 with the 3.9 engine.
When I insert the key and turn it to RUN, everything is fine but when I turn the key to crank the engine, all the electrical power cuts off. No dash lights, no cranking, nothing. It stays that way when I release the key. Only by disconnecting and reconnecting the battery can I get power back, but when I go to crank the engine again, the whole process repeats.
I have pulled and tested the ignition switch and it seems to be ok.
Does anyone have any thoughts or advice?
Regards,
~rick
Old May 10, 2011 | 09:17 AM
dnfd737's Avatar
dnfd737
is the battery good? Check the ground from the battery infact check all battery conections.
Old May 10, 2011 | 02:00 PM
Ramzy's Avatar
Ramzy
^^^Def battery or connections.
