engine and clutch problem
Old May 17, 2011 | 12:30 AM
big blk rex's Avatar
big blk rex
okay i had clutch slave pulled out the rod is moving no air in the lines
Old May 17, 2011 | 09:20 AM
How many miles on the clutch/pressure plate?
I take it you can't see what the rod is doing when installed? Need to put some sort of load on the slave, to see how things really are.
Old May 17, 2011 | 01:54 PM
big blk rex
okay thats sounds good i dont know how many miles are on the clutch?
Old May 17, 2011 | 02:06 PM
Probably the same as what is on the truck then.......
Old May 18, 2011 | 10:29 PM
big blk rex
Hey i got news for u all the friction disc spring broke caused a big score in fly wheel broke clutch pressure plate clutch bent my fork caused alot of problems dang it so i wasnt clutch slave or clutch master just alot of broken piceces thanks for all help
