Going to service my trans this weekend
Old May 21, 2011 | 01:14 AM
Josh_Putman's Avatar
Josh_Putman
Default Going to service my trans this weekend
Well, it is finally time for me to service the trans in my truck. I have had it for about six months or so, and it has about 75,000 miles on it now. I have been doing a lot of reading here, so I think I am prepared.
My plan of attack is to change the filter, install a drain plug in the pan, clean the solenoids attached to the valve body, and install a remote filter in the line that USED to contain the check valve (I got rid of that a few months ago).
The reason for the remote filter is that I feel it would be much easier and quicker to change that than the one in the pan, and it would actually keep the internal filter from getting very dirty in the first place. I plan on replacing the remote filter a couple of times in the next few weeks, just in case the new fluid breaks some crud loose.
Does this sound like a logical plan, or is there something I should add?
Old May 21, 2011 | 01:29 AM
CPTAFW163's Avatar
CPTAFW163
Forget the remote filter. get this:
http://www.summitracing.com/parts/DER-14210/
I have it. I needed to get it because the tranny plug I installed was hitting a solenoid (drilled the wrong side). Plus, that pan adds cooling, has a bung for a tranny temp sensor, and has a drain plug.
Also: SAVE YOUR STOCK GASKET!!! It is a hard plastic gasket that makes it a bit more FORGIVING if you accidentally overtorque your tranny pan. Those pans BEND after 35 ft lbs and they will leak. That is why i don;t send my truck to those "lube" places. They ALWAYS overtorque. THat causes tranny leakage on the seams of the pan.
THe remote filter is not necessary. And 75K miles is not a lot. However, i would send it in to get done professionally at the dealership. i believe it is 120 dollars for a drain and fill AND they adjust your bands. I didn't do that myself because you can mess it up easy, and i do not have a very good torque wrench.
Old May 21, 2011 | 01:31 AM
CPTAFW163's Avatar
CPTAFW163
BTW, that tranny pan keeps tranny temps low. The highest I have seen my tranny temp was about 145. Mostly it stays around 100. Especially on the highway. After hours of driving on the highway, then pulling off into city traffic, the temp will go to 125-140.
Towing/hauling 3100 lbs out of overdrive only got me to 129 degrees with that pan. Plus it is slightly deper. You can hold another 2.5 quarts.
Old May 21, 2011 | 07:51 AM
dhvaughan's Avatar
dhvaughan
i have a remote filter and like it. about once a year i drain/refill the pan and change the remote filter only. this is not recommended, but i do it anyway. about every 2 years i drop the pan and change the internal filter.
take your time drilling the drain plug hole. center it on one of those flat panels, and look at what's inside, as there are a lot of obstacles inside that the plug body can hit. some of the plug bodies are overly long. you can grind off the excess.
you can also put it one the bottom or the side. it doesn't have to drain 100% of the pan, just most of it. the last one i did i put in the side, where it can't drag on a rock.
also consider adding a cooler.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
