Will this transmission fit my truck
Old May 21, 2011 | 05:13 PM
ericsharma's Avatar
ericsharma
Default Will this transmission fit my truck
Hi. I have a 1998 Dodge 1500 4x4 with the 5.9 gas engine and the automatic transmission just went out (206,000 miles). I found a transmission from a 2000 2wd pickup for sale. It has 95000 miles and is $200. Does anyone know if this will fit my truck. I know I would have to change the tail shaft over from my old tranny to accomodate the transfer case but I don't know if the tranny will fit. The owner bought if for a parts truck for some body parts and the engine and he said it drove fine when he drove it home (4 hour drive). The donor pickup had a V8 engine also. Any help would be appreciated. Thanks.
Old May 21, 2011 | 05:54 PM
dodgeman2289's Avatar
dodgeman2289
i believe so.. we have the 46re and 47re find out if its one of those if so it should work just fine.
Old May 21, 2011 | 06:44 PM
97tn4x4's Avatar
97tn4x4
The 4wd and 2wd have different out puts. It will work but will require some work.
Old May 21, 2011 | 07:12 PM
Like completely disassembling it to change the shaft.... at least, the O/D section..... housing may be different as well. (might be able to just take off the tailshaft housing to fix that though.... not sure.)
If you just want a direct swap trans, get one out of the same year truck, that is also 4x4. Otherwise, you may run into additional issues. (different connectors, pinouts, and such.)
