98 ram engine swap wont start
Old May 22, 2011 | 01:06 PM
01BlAcKsPoRt's Avatar
01BlAcKsPoRt
Default 98 ram engine swap wont start
I have a 98 ram, bought it with a blown engine. I bought another motor with 103,000 miles, heard it run before buying it. I did a regular tune up after I dropped it in, but now it wont start.
It'll start if I force feed it fuel through the intake.
So it does have spark but not enough fuel pressure and the fuel pump engages when I turn the key to the on position. But it stops suddenly after about 1 sec.(i had someone turn the key while I stuck my head under near the tank).
So I dont know if its the fuel pump itself, or just some other component that is not connected or malfunctioning.
any clues?
Thanks in advance
Old May 22, 2011 | 01:26 PM
Ramzy's Avatar
Ramzy
Fuel pressure is prob too low. Sounds like you have good spark. The pump will stop after turning the key on if it is not started.
Old May 22, 2011 | 04:38 PM
01BlAcKsPoRt
never mind, the throttle cable was not routed correctly; fixed it and started right up.
thanks ramzy
Old May 22, 2011 | 04:57 PM
Ramzy's Avatar
Ramzy
Glad to hear. I've done the same type of thing many times.
Old May 22, 2011 | 10:22 PM
CPTAFW163's Avatar
CPTAFW163
I once installed the throttle linkage on my carbd SBC BACKWARDS. I got a better carb and it required the routing to be reversed from stock. So When i turned the key it was at WOT.
