very sluggish
Old May 22, 2011 | 08:39 PM
rmyzfr66988's Avatar
rmyzfr66988
blew out the trans and had it rebuilt. maybe a week after that i was havn shift problems and shift points were off. they replaced solonoid and valve body again. 2 weeks later had same problem. they hooke dit up and figured out the computer was toast. so i changed the computer. and it was running good until the comp took another **** . so i bitched and they got me another computer and reflashed it and i put it in and that should bring the issues to current
Old May 22, 2011 | 08:46 PM
rmyzfr66988
had the trans rebuilt. 2 week later had all sorts of shift problems. they changed solonoid and valve body. 2 more weeks go by and still have problems and it was lacking serious power. they looked at it again swapped in a totally diff rebuilt trans. and had same problems so they looked into the computer and found it was shot. so i put a new one in and it was ok for about a month then it went out. they got me a new one and flashed it and i swapped it out . and that about sums it up
Old May 22, 2011 | 08:49 PM
kejobe's Avatar
kejobe
If it started after the last comp was installed, i would assume it would have to be the comp or the tune it was flashed with.
Old May 22, 2011 | 08:50 PM
rmyzfr66988
that is what i was assuming. i just wasnt sure if the trans was malfunctioning again or if it was that. thanx for the insight
Old May 23, 2011 | 12:23 AM
lastrights's Avatar
lastrights
Maybe contact hemifever for a act and have a real good tune written.. its a day and night difference. Maybe the second computer has the deathflash
