DTE / MPG computer calculation ??
Old May 23, 2011 | 01:06 PM
Paulietools's Avatar
Paulietools
Default DTE / MPG computer calculation ??
I am wondering if anyone can tell me how DTE / MPG is calculated by our trucks?
I am guessing that since the display in the overhead console is coupled to the onboard CCD bus that it receives its info this way.
We have the optional 34 gallon tank in our truck but with all my research it appears that the fuel sending unit is the same for the standard 26 gallon tank. It seems to me that using the same sending unit in different size tanks would cause an error in the calculations unless there is programming change done in the PCM or other computer to account for the difference in math.
This also ties in with the confusion that I have about using the same sending unit in two different size gas tanks but still still getting accurate gas tank level readings.
Any ideas or thoughts?
Old May 23, 2011 | 01:09 PM
I think the larger capacity tanks are just longer, so, fuel sending unit remains accurate.
I have no clue how it calculates mileage, or DTE.
