My brake problems, part III!
Old May 31, 2011 | 08:41 AM
bobboraze's Avatar
bobboraze
Default My brake problems, part III!
I swear this shall be the last thread about my damn brakes....
As a quick recap, somethings goofing up with my brakes, truck will drive fine, then randomly the front brakes will lock up. I have to ride the brakes home, after it sits a bit (or if on hwy, pulling over for a sec), it clears up and drives normal.
I've replaced: calipers/rotors/pads/brakehoses it's like a brand new system... the pedal never feels odd, I don't believe the master cylinder is an issue. (fluid was never fully flushed though)
The only recent issue, out of no where the brakes started doing their thing again, except this time my CEL came on, along with the BRAKE and ABS lights, and the speedo stopped working. I've found this issue to be a bad sensor above the differential, easy fix that I shall be doing later today.
http://wiki.answers.com/Q/What_could..._Ram_1500_AWAB
YET, I'd like to think this has something to do with the issue I'm having with my front brakes? Could be completely unrelated, yet the brakes started acting up again relative to the lights coming on.
Any help is greatly appreciated!! (like big time)
Old May 31, 2011 | 09:31 AM
Do you have four wheel ABS?
The speedo/brakelites problem is probably due to a failing rear wheel speed sensor.
Old May 31, 2011 | 02:42 PM
bobboraze's Avatar
bobboraze
The cel and all that matches that link I posted, to the T. I have no doubt it's that sensor above the differential. I'm curious if the front brakes locking up might have anything to do with it? Doesn't make sense to me that it would. Yet odd coincidence...
Old May 31, 2011 | 02:47 PM
RedRam59360's Avatar
RedRam59360
Without ever touching the brakes the front brakes lock up? In my opinion I would have to say it is either a Master Cylinder problem.. Or a brake booster problem. If you have a cracked seal inside the booster.. It might be causing the brakes to apply on their own. Try disconnecting the vaccum line (and blocking it off of course) and driving with manual brakes.
Old May 31, 2011 | 03:00 PM
If you have 4wal, it might make sense... if you only have RWAL, then the two have nothing to do with each other.
Old Jun 1, 2011 | 02:14 PM
bobboraze's Avatar
bobboraze
It's hard to tell if the brakes lock up without touching. This happens every few days or so, nothing consistent. I can't really drive with manual brakes waiting to see if it pops up unfortunately.
I don't believe I have 4wal. All I see is the brake hose going to the caliper, no other cables/wires. Guessing it's unrelated.
Old Jun 3, 2011 | 02:16 PM
bobboraze's Avatar
bobboraze
Ok so turns out an adjustment was off with the rod coming out from the brake booster. I'm hoping this fixes it... we'll see if anything comes back.
The speedo sensor seems to be an unrelated issue. Easy enough of a fix though.
