Master Wiring Terminal Data Sheet?
Old Jun 3, 2011 | 08:32 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Master Wiring Terminal Data Sheet?
I am having troubles with the wiring on my truck, and need to replace some of it and add on to some of it(as in placing auxillary light relays in the PDC). Is there somewhere that has what terminals I would need for various components? I'm talking about sensor terminals, relay terminals, PDC terminals, the works. And is there anywhere to get those nifty wire ties with the sheetmetal anchors? Thanks!
Old Jun 3, 2011 | 09:10 PM
Grab the 01 service manual from the FAQ section here, it will have all the wiring diagrams you need.
Old Jun 4, 2011 | 06:29 AM
johnnyrocket5363
No, not diagrams (I grabbed that one a LONG time ago). I need the actual little pieces of metal that go inside of connectors so I don't try to solder in so many places. I have no idea about part numbers or where to get them. Also, is there anywhere to get replacement connectors besides the stealership?
Old Jun 4, 2011 | 10:14 AM
Oh. That's a different story.
You should be able to get them from an electronics supply shop..... might wanna talk to a body shop or two as well, and see if they don't have some ideas.
There is a neat little tool you can get to pull the metal parts out of the connectors, if all you need to do is re-pin them.......
Aside from that, the dealer might be your only option.
Old Jun 5, 2011 | 05:28 PM
johnnyrocket5363
Ok, cool! Any other suggestions?
