96dodge no power to feul pump
truck ran fine then started to run real ruff then dyed, thought it might be feul pump put new one in still don't run found out no power to pump fuses good,relay good have juice to cam sensor,crank sensor,and have spark so i am stumped if anybody can help i would be greatful need my truck, by the way it is a ram 1500 4x4
Thanks
Thanks
Any codes....sounds like an asd relay but the only thing is you still have spark might want to trade it out with another relay just to make sure, also check wires to fuel pump to make sure that its not cut.
