Smoke/Oil burning, valve seals?
Old Jun 9, 2011 | 09:35 AM
97_DodgeRam's Avatar
97_DodgeRam
$800 seems a very high, what does your mechanic charge per hour? I'm doing valve seals and the plenum fix on my truck this week. For all the gaskets, new head bolts, and the plenum kit its about $320 after shipping and handling. And one lazy saturday or sunday with my own free labor.
May be worth just taking your time and doing it yourself, or have a friend with some experience to help you.
Old Jun 10, 2011 | 05:59 PM
nmason's Avatar
nmason
yeah, neither i nor my friends have any experience with that stuff. as for my sense of adventure, i would have more if i had a 2nd vehicle
the door pin just let go today and my door almost hit the ground. so dealing with that now too. things come in threes right?
Old Jun 11, 2011 | 12:06 AM
CPTAFW163's Avatar
CPTAFW163
the plenum is pretty easy, you just need a weekend to do it. I took my time. Use zip ties to get hoses and wires out of the way. And don't un-clamp your distributor like I did. I was lucky and fixed it before I turned the engine.
The keys to doing the plenum are these:
1. Put all bolts back into the parts you took them out of. Like the accessory bracket. Some are longer/shorter.
2. Clean off all the old RTV from the engine block. Really clean the surfaces. i needed to dig some old RTV out of the block at the front and back so the front and rear gaskets could fit in there. THose gaskets have little nipples that go into the block. If they are clogged with RTV, which they will be, and you DON'T clean it out. YOu can possibly leak oil. Cleaning the surfaces takes the most time.
I did roller rockers, new injectors, and put in a MSD box as well. So that is why it took extra time. Otherwise, it would have taken a day. 4 hours probably.
Old Nov 2, 2018 | 01:39 AM
The5.9king's Avatar
The5.9king
Default Well let's see
I did all of it I pulled my 5.9 out tire it down and done every ring, bearing, and gasket in and on the engine, then had the heads re built had the valves set but after 4 to 5 thousand miles in got a little smoke but only when I hammer down on it but that also comes from it having no cats and true dual straight pipes out the back but I came to find that the plenum gasket is leaking a little bit due to it not sealing properly a word of advice if it does not say OEM on it DONT BUT IT no matter the name
Old Nov 2, 2018 | 02:37 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The problem is the OEM is flawed from the get go. You need shorter bolts, you probably bought the kit with the factory length bolts. Also this is an old thread.
