installing new rear shocks,not compressed
just bought a set of Monroe Sensa-Trac load adjustinging shocks for my '96 ram 1500 4x4.they have the big *** coil spring over them.problem is they dont come compressed.so do you install them by jacking truck up to full drop?or is there a better way?
thanks
thanks
You should be able to pop then in at full drop. I was able to when I was running the Gabriel load levelers a while back.
they are a little tricky, but the method I took after chocking the front tires was to jack on the drop pintle plate to raise the rear. I anchored the shocks at the top, and then was close enough I was able to use a pry bar to get it in the saddle (handle at ground lifting the handle up. flipped the prybar over (handle in the air now) to get under the shock end and raise it up to meet up with the eyelets. Over all it wasn't too bad, but be prepared for what comes next hahahahaha. Squeaky springs lol, give it a year or two
If the spring is your problem then rent a spring compressor. Thats the safest and easiest way to compress them. Any auto parts store should have a loaner set.
Trending Topics
after messing with these big suckers in the garage i decided to bite the bullet.sometimes a guy just needs help to accomplish all tasks at hand.gonna pay to have them installed.
thanks again for the replies.
