Hughes plenum plate or just new gaskets?
You will need an intake gasket set and if you're going remove the throttle body you will need the throttle body gasket.
http://shop.advanceautoparts.com/web...AMS_1726003575____
You'll probably also want to get some gasket maker/RTV. If you got the kit off of ebay from 1999blkdakrt it says it comes with bolts.
ahhaha i didn't mean to, i was on my iphone and the darn autocorrect hates me with a passion...
yup.. and get the felpro set.. it is often cheaper, and comes with a new TB, WP, Timing, Intake, and Plenum gasket set as opposed to just the plenum/intake gaskets..
I HIGHLY rec you do the timing chain too.. get a stout double roller.. that, all by itself, will awaken your ride..
