Replaced a bunch of parts and still getting low MPG
Old Jun 15, 2011 | 11:26 PM
weatherman929's Avatar
weatherman929
Default Replaced a bunch of parts and still getting low MPG
I have a 2001 dodge ram 5.9 off road edition and I replaced a bunch of parts and went from 5mpg to 10mpg but I feel like most people get 13-15
Heres what I've replaced:
- Both O2 Sensors
-TPS
-All new upgraded Bosch injectors
-Air Filter
-Coil
-Plugs, Cap, Rotor, Wires
I am also getting the P0455 code but would that cause the low MPG's? Anyone have any ideas?
Old Jun 15, 2011 | 11:35 PM
You have a vacuum leak in the evap system, and yes, that may have a negative effect on fuel economy. Fix that.
What brand O2 sensors?
What flow rate on the injectors?
Old Jun 15, 2011 | 11:54 PM
weatherman929
Bosch O2 sensors and as for the injectors I was told they flow 1lb an hour more than stock but they have 4 hoes instead of one for better fuel atomization
Old Jun 16, 2011 | 12:07 AM
Rob59's Avatar
Rob59
Honestly 10mpg probably isn't too far off if it's city driving. I mean my 5.9 4x4 is only rated at like 12 city as a brand new truck, and yours is an off road which means higher gearing (4:10's?) I can completely see you getting 10mpg with the 5.9 and that gearing with a ten year old truck. With that said, definitely fix the vacuum leak as that can definitely be hurting your mpg.
Old Jun 16, 2011 | 02:22 AM
jasonw's Avatar
jasonw
Site Moderator
+2 for vacuum leak.
Also, Bosch O2 sensors are known to be hit or miss on quality. Denso or NGK are usually the way to go, for future reference. Cost a little more, but much better quality usually. Rock Auto has great prices on the Denso units usually.
Old Jun 16, 2011 | 09:52 AM
dodgeramit_10's Avatar
dodgeramit_10
+3, Take starter fluid and spray around each injector while running. If your truck jumps in rpms you found a leak. I had a leak in 2 of mine after I put the FI airgap and I gained a full mpg or 2 after fix.
