96 Dodge Ram won't start
Old Jun 17, 2011 | 07:28 PM
amurray688's Avatar
amurray688
Default 96 Dodge Ram won't start
I have a 96 1500 5.2L, 5spd. It died while driving up the interstate as i accelerated to pass, and wouldn't restart. When cranked, it will start for about 2 seconds and die again. I checked and it seems to be getting both spark and fuel. I have also replaced the crankshaft position sensor, and have checked all of the wires to make sure the connections are correct, and as it died from running fine, I cannot figure out what the problem is. Any suggestions?
Old Jun 17, 2011 | 11:32 PM
Does the fuel pump prime when you turn the key on?
Can you check your fuel pressure?
You might have pressure, but, are you getting injector pulse?
Where did you get your cam sensor? These trucks don't much care for aftermarket parts in critical locations......
Just for grins, try swapping the ASD relay, for the horn relay. See if that doesn't improve it's attitude.
Old Jun 18, 2011 | 05:53 AM
stands2p's Avatar
stands2p
interesting that there hasnt been one thread with a 5v supply ground out no start in 4+ months.who was it that stopped posting 4+ months ago exact same time?quackery or coincidence?
Old Jun 20, 2011 | 10:14 PM
ClubCab5.9's Avatar
ClubCab5.9
Have you found a fix for this issue?
Stands2p....Quackery. Any other thoughts?
