recon cab lights
Old Jun 19, 2011 | 10:19 PM
deerehunter's Avatar
deerehunter
o wow that is very cheap. i have a homemade one but nothing can go through it. Crushes those deers skulls though. Sorry I meant on the cab lights.
Old Jun 19, 2011 | 10:24 PM
dodgeramit_10's Avatar
dodgeramit_10
O god what was it I believe I used half also to get the wire in the directions stated to pull the fitting off and tape the wires together I really didnt like the idea so I drilled a whole big enough to fit the plug in. As far as for the screws I also believe 1/8 thats in the directions for sure the hardest part is drilling the first whole and having a buddy that you can trust to help you make sure everything looks straight. Also had the DIY from the forum on my comp just to triple check everything.
Old Jun 19, 2011 | 10:31 PM
deerehunter
how did the plug fit in afterwords?
Old Jun 19, 2011 | 10:33 PM
dodgeramit_10
I kept the fittings on and just plugged them in the wiring kit had female ends and the lights had male the hardest part is drilling the holes everything else is a gravy train.
Old Jun 19, 2011 | 10:36 PM
deerehunter
allright thanks for the advice and help
Old Jun 19, 2011 | 10:41 PM
dodgeramit_10
No problem if you get the kit and have any problem or questions shoot me a PM.
