97 ram dana 44 gears ?
as said standard rotation.
the only variable you have to worry about is the carrier and gear thickness.
3.92-4.88 gears in standard thickness use a special carrier.
3.73-3.55 use a standard carrier.
3.92-4.88 THICK gearset can use the standard carrier and save you the $50-100 to replace the carrier. however, the thick gearset might cost more than that.
