Plenum Question
Old Jun 21, 2011 | 10:24 PM
lawman5050's Avatar
lawman5050
Default Plenum Question
Getting ready to replace the plenum with a new aluminum plate and new felpro gaskets as well as a full tune up.
For those of you who have done this before, which gaskets did you use the black RTV gasket sealer on? I know you put it in the corners of the intake but did you use any on the plenum gasket it's self or the gaskets between intake and the heads?
Thanks!
Old Jun 21, 2011 | 10:49 PM
RamSport97's Avatar
RamSport97
I believe I just used it on the corners, do not use any on the plenum gasket itself.
Old Jun 21, 2011 | 10:58 PM
J415's Avatar
J415
I put some on the corners of the end seals (china walls) as well as around the coolant ports. If you do the same, make sure you only put a THIN COATING on .
