rebuilding 46re/a518 transmission
Old Jun 23, 2011 | 10:36 PM
thexh20's Avatar
thexh20
Default rebuilding 46re/a518 transmission
rebuilt all seals n bearings, clutches and steels and bands, but here is what the kick me in the ***** did, , putting it all together...the OD unit/output shaft wont let me connect to the main case so im frozen like a ********...something stuck wont go right in or its just not aligned, sum trick i need to get it in somehow...help me out here, pls..
Old Jun 23, 2011 | 10:39 PM
Do you have the splines for the clutches/steels in the OD unit lined up? If any of them are off, you won't be able to slide it onto the shaft.
Old Jun 23, 2011 | 10:56 PM
thexh20's Avatar
thexh20
i went to the transmission shop today and took off the snap ring off from the compressor tool so i can replace the clutches n steels and then the guy came back with the aligned tool. he put it in, aligned it and then took it out, then i compressed it again to put back the snap ring..but im thinking the aligned tool should be in it while compressing it to put the snap ring in or something else..
Old Jun 24, 2011 | 06:28 AM
neilsrpcustoms's Avatar
neilsrpcustoms
Nope, can't leave the alignment tool in it, and you have to be sure to be very gentle reinstalling the unit on the out-put shaft,so as not to accidentaly spin the sun gear.If it does happen though,you can usually give it a left to right spin washing motion and get it to come back into alignment with the shat engaged on the first set of spline.
Oh yeah, don't let the intermediate shaft support that od and direct drive clutch housing in any way, you'll wipe the bushing in the back of the main housing.
Old Jun 24, 2011 | 02:18 PM
thexh20's Avatar
thexh20
im gonna go ahead and take the immediate shaft out and try to align it in the od unit again..see if that works. let u guys know!
Old Jun 25, 2011 | 12:41 AM
thexh20's Avatar
thexh20
Ur right..i had to align it correctly 3-4 times. Got it connected n successfully went thru..fr bottom to top, i did it in 3hrs w sum breaks in between infos abt 46re online and clerance. Not bad for first timer..one thing abt the band adjustment, which tool can i use to adjust it w the torque tool on? I had to use a loose socket that barely fit and i think i did it right..now the valve body is in w the park rod installed n oil filter kit..tmw gonna torque it up the oil pan. Then it goes in the truck..jus cant wait to start the engine and see if it actually moves.
Old Jun 25, 2011 | 01:03 AM
J415's Avatar
J415
I believe an 8 pointed socket will do just fine
