plz help
Old Jun 26, 2011 | 01:15 AM
crashandburn19's Avatar
crashandburn19
Default plz help
hello i have a 97 ram 2x4 long bed i want to run true dual exaust but my problem is what do i do with my o2 sensors i dont want worse mpg but i want the great sound tx all
dodge for life
Old Jun 26, 2011 | 06:26 AM
97_DodgeRam's Avatar
97_DodgeRam
I'd get high flow cats, they help with emissions, a little back pressure, and the cats along with the o2's allow your truck to run as close to Stoichiometric as possible "ideal air-fuel ratio" But if anything I would at least the the pre-o2 sensor on. Since that's the most important of them all, that being said, o2 sensors were designed to work with and read off each others readings.
Besides all that junk, that question is how bad do you want the noise over the mpg? once thats figured, you'll know what to do with your exhaust.
Old Jun 26, 2011 | 06:35 AM
Mpi360's Avatar
Mpi360
Put it in pass side down pipe. Pacesetter long tube's have the o2 placed in the pass side collector reading on side. Reading one side is not an issue or they wouldnt do it like that. What ever you do do not put it in a H pipe. Not enough flow within the H.
Old Jun 26, 2011 | 10:08 AM
merc225hp's Avatar
merc225hp
Yes use H cross over and here are some pics of what I run for exhust. 02 are in the H pipes.
