what rear end do i need
Old Jun 26, 2011 | 03:44 PM
doug1978's Avatar
doug1978
Default what rear end do i need
ok i have no idea when it comes to gears and what not i have a 97 ram 4x4 5.9 with 35s on it i think it has 355 now and i just want to put them back in i dont find it bad on gas so i want to keep it this way or is there something better out there for me to put in i want to change the whole rear end i can get one from a 97 ram thats 3.9 5 spd or a 98 2 wheel drive with a 318 in it will any of theses work or i can get every thing from a 96 3/4 ton i just want whats best for this truck as i drive it everyday pls help thanks
Old Jun 26, 2011 | 04:11 PM
1&2genrams's Avatar
1&2genrams
forget about the 3.9 and the 2wd 318, they are too weak and you need both front and rear diffs, the 3/4 ton diffs will be stronger and better suited to 35's.....gear ratio....well I've done it all, driven 35's on 3.21, great highway revs but extremely taxing on the little 318 around town, then switched in some 1 ton diffs 4.10 ratio....killed the highway revs (it was a 727 trans, no o/d) but fixed the lower rpm stuff, my suggestion, grab the 3/4 ton gear and 4.10's as you have o/d......you will burn a little more gas, but you will be closer to the stock ratio the truck was built with so the rest of your drivetrain will be happier.
Old Jun 26, 2011 | 09:40 PM
jasonw's Avatar
jasonw
Site Moderator
No offense, but periods and other punctuation marks are your friends. People will be more willing to help if they can read your post.
Not trying to be mean, just giving it to you straight.
Old Jun 26, 2011 | 10:32 PM
doug1978's Avatar
doug1978
so maybe i should try grabbing the whole 3/4 ton .. and just bring it home swap everything around ? but then i have to use 8 bolt rims right.. or will the axles swap to i no nothing when it comes to this sorry
Old Jun 26, 2011 | 10:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes you'll need 8 lug rims. Get the whole truck , you'll need the driveshafts, leaf springs and other various parts. It's not just a straight up swap.
