Need help blown head gasket
Old Jun 27, 2011 | 11:02 AM
A_POLVADO's Avatar
A_POLVADO
Default Need help blown head gasket
Ok first off 2001 ram 5.2
Blew the head gasket when I pulled everything apart to replace it had water in the intake along with oil from the infamouse intake leak and valley none in oil pan (Caught it quik) So I fixed the heads started engine ran rough as hell like a bad miss then I noticed no oil pressure love a dodge pulled the oil pan pick up was clogged cleaned pick and pan. so truck is running but rough. i guess my question is the valve train i think my buddy torqued them down to tight if possible or im leaning towards bad cat and o2s any ideas would be greatly appreciated
Oh and directions on valvetrain assembly
thanks
Anthony
Old Jun 27, 2011 | 11:26 AM
Any codes?
Make sure you have your plug wires in the correct order, and routed according to the TSB.
All the injector connectors nice and tight?
Old Jun 27, 2011 | 11:40 AM
Annihilator_X9's Avatar
Annihilator_X9
Did you change your oil? It's nothing to do with your problem, but I'd do it anyway since you got coolant in it.
Old Jun 27, 2011 | 12:03 PM
A_POLVADO's Avatar
A_POLVADO
yEA FLUSH THE ENGINE WITH DIESEL THEN PUT IN MOBILE 1
