need to haul 1200 pounds of dirt...
Subscribe
Jun 27, 2011 | 09:33 PM
Thanks guys for all the input!
Its only a short trip, about a 15 minute drive at city speeds.
I wont use overdrive, and hopefully will be ok.
Reply 0
Jun 28, 2011 | 12:58 AM
Sh^t if it holds overdrive use it, if you think about it 1200 pounds is not much you could have more than that in the bed going on a camping trip.
And if your brakes noticeably are affected you need to redo some brakes I take my bike about 800lbs all the time and never notice it, and the toolbox in the bed is close to 300lbs
Reply 0
Jun 28, 2011 | 02:46 AM
Quote: Sh^t if it holds overdrive use it, if you think about it 1200 pounds is not much you could have more than that in the bed going on a camping trip.
Negative, do not use O/D. That is, unless you want to be rebuilding your transmission soon. O/D is where these trannies work the hardest, and they are not designed to pull anything more than the truck itself (empty) + passengers in O/D.
Reply 0
Jun 28, 2011 | 03:26 AM
I havent had a problem yet using OD, my truck only has 178K on the stock tranny, I pull my bosses trailer, about 2k without a problem, now the boat gets OD off.
I have always gone by if it holds OD and doesnt hunt its not gonna hurt anything
Reply 0
Jun 28, 2011 | 11:47 AM
believe it or not, I have put 4200 lbs from concrete bags in my truck on a 40 miles trip, 3 or 4 times, and nothing bad happened. mine is 98 1500 2wd 5.2, if mine can handle that weight every ones ram can
Reply 0
Jun 28, 2011 | 11:50 AM
Quote: believe it or not, I have put 4200 lbs from concrete bags in my truck on a 40 miles trip, 3 or 4 times, and nothing bad happened. mine is 98 1500 2wd 5.2, if mine can handle that weight every ones ram can
1200 pounds, I wouldn't worry. 4200 pounds, I'd be worried about busted leaf springs or shackles.
Reply 0
Jun 28, 2011 | 11:54 AM
I once killed a grizzly bear with nothing more than a loose leaf notebook.
Reply 0
Jun 28, 2011 | 12:04 PM
Quote: I once killed a grizzly bear with nothing more than a loose leaf notebook.
You sir, are amazing.
Reply 0
Jun 28, 2011 | 12:15 PM
if you don't try, you never knows if its possible. I have as witnesses 2 chevy guys, I get in my truck the extra load that they refused to put in their 30 mpg trucks
Reply 0
Jun 28, 2011 | 12:22 PM
Quote: if you don't try, you never knows if its possible. I have as witnesses 2 chevy guys, I get in my truck the extra load that they refused to put in their 30 mpg trucks
Reply 0
