Sound in Overdrive
Old Jun 27, 2011 | 06:53 PM
JRod17's Avatar
JRod17
Default Sound in Overdrive
I have a 1997 dodge 1500, when I am in overdrive and on the gas, I hear a clicking/light rattling sound. It doesn't sound like warn lifters. I don't know what it is, thought maybe some of you guys might have an idea?
Old Jun 27, 2011 | 06:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Front axle or drive shaft ujoints? Is it a pinging noise? Does your cat rattle if you bang on it?
Old Jun 27, 2011 | 08:31 PM
Ramzy's Avatar
Ramzy
From the post it sounds like you think is is coming from the engine. If it is pinging under load, think marbles in a can, you may want to check this out,
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jun 27, 2011 | 10:04 PM
JRod17's Avatar
JRod17
Its not the front axle. and I checked outhe U joints and look and feel fine, no sounds from them that I can tell. Annnd there are no cats.
Old Jun 27, 2011 | 10:08 PM
JRod17's Avatar
JRod17
[quote=Ramzy;2537242]From the post it sounds like you think is is coming from the engine. If it is pinging under load, think marbles in a can
Hmm. I'm haven't been pulling any loads lately, but I suppose I should check the plenum out. I'm not sure if the previous owner changed it or not. worth a look though.
I was thinking that it could have been coming from the trans. since the noise only occurs in overdrive, and not in any of the other gears.
