How can I check my tps?
Old Jun 28, 2011 | 07:31 PM
Joey Buentello's Avatar
Joey Buentello
Default How can I check my tps?
I was told to check it by pulling the wire harness and checking it with a volt meter. Got 5 volts. How does this check the sensor itself.
Old Jun 28, 2011 | 07:35 PM
With the sensor plugged in, one wire should have the 5 volts. another wire should be a ground, I believe the middle wire is the signal wire, and that is the one ya wanna have a look at. With the throttle closed, it should be right in the neighborhood of one volt. As you open the throttle, voltage should increase steadily, no jumping around, up to greater than 3.5 volts at WOT.
If your voltages are out of range, or, the voltage jumps around, replace the sensor.
Old Jun 28, 2011 | 07:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The Haynes and the free downloadable service manual in the FAQ section also has the test procedure. Not that HeyYou didn't do a great job as usual , just figured I would point that out.
Old Jun 28, 2011 | 09:28 PM
Joey Buentello
I have a hayes manual. I don't think it explains how to check it. Anyhow It's getting a little over 3 volts at wop. thank you very much.
Old Jun 28, 2011 | 09:30 PM
aim4squirrels's Avatar
aim4squirrels
Probe the center and right most wire with a voltmeter set to read to .01 volts. Turn the key on, but don't fire up the engine. Starting voltage should be anywhere from .30-.70 volts. WOT should be around 4.5v, but what you are looking for is a gradual step up in voltage from idle to WOT, without big skips in voltages.
Old Jun 28, 2011 | 09:41 PM
Joey Buentello
I might have had a higher reading than that on start up. I think the increase in voltage was gradual though. Do you recommend I just puncture the wires insulation?
Old Jun 28, 2011 | 09:45 PM
aim4squirrels
Yep.
If your idle voltage is over .75v, first check for obstructions to the throttle plates and linkage, them replace the sensor if you dont find any as the sensor is too far out of spec.
Old Jun 28, 2011 | 11:02 PM
JSTMoto's Avatar
JSTMoto
For a similar bit of troubleshooting, I've used a needle to puncture into the wire, and then I'd hook my multimeter to the needles.
-JT
Old Jun 29, 2011 | 04:01 AM
Joey Buentello
thanks
Old Jun 29, 2011 | 03:12 PM
zman17's Avatar
zman17
Not to make a big deal out of it, and just for future reference for someone that does a search here on DF about the same topic. The test procedure for the TPS , IS in the Haynes manual. Along with test procedures for just about all the rest of the sensors. All they will have to do , is actually look.
