Tire size. im dumb haha
Old Jul 1, 2011 | 01:28 AM
VinsBlackRam's Avatar
VinsBlackRam
Default Tire size. im dumb haha
Are 285/75s 33inch tires? idk standard tire size.
Old Jul 1, 2011 | 01:44 AM
JackJ's Avatar
JackJ
http://www.google.com/#sclient=psy&h...w=1680&bih=967
Old Jul 1, 2011 | 02:09 AM
redheadhunter21's Avatar
redheadhunter21
285/75/16 is a 33x11.5-16
Old Jul 31, 2011 | 12:42 PM
dodgenram1500's Avatar
dodgenram1500
285s are actually 32 cause i just bought 305/70/r16 mickeys and there 33inch tires
Old Jul 31, 2011 | 12:49 PM
dhvaughan's Avatar
dhvaughan
here you go, this one has metric sizes and inches (to the right - under additional sizes)
http://www.1010tires.com/tiresizecalculator.asp
JackJ's Avatar
JackJ
plug you numbers in here, 305/70's are 33x12.5, 285/75 are 33x11.2
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Jul 31, 2011 | 02:32 PM
shorty24v's Avatar
shorty24v
here is a walk through if I typed up for someone a couple weeks ago
How you figure out a metric tire (I will use 285/75 16)
285 means 285mm wide.
75 means the sidewall it 75% of 285mm.
16 obviously means the rim diameter.
For the rest of the example I will use round numbers.
again I will use a 285/75 16 tire.
285mm to inches is about 11
75% of 285mm is 213mm
213mm to inches is about 8"
to find the tire height you do sidewall (8") x 2 + rim size (16")
(8x2)+16 = 32 I rounded down through the whole thing but it ends up to be 32.8" high.
Hope this helps and makes sense.
