need ac help please
Old Jul 2, 2011 | 05:54 PM
Beerthirty86's Avatar
Beerthirty86
Default need ac help please
Hello...i have a 2000 ram 1500 5.9l....the other day my ac stopped blowing cold. I check my fuses under the hood amd noticed the ac clutch fuse was blown and procceded to disconnect the neg battery terminal and replace the fuse. With the new fuse in i started the truck and to no avail it wont blow cold. So i look back to the fuse box and the new fuse i just put in was blown.....any advice?... i also noticed my ac clutch not turning when the truck is on....and advice will be greatly appreciated. Thanks
Old Jul 2, 2011 | 09:07 PM
Holly Magnum's Avatar
Holly Magnum
sounds like a wire has worn through and is shorting and blowing the fuse
Old Jul 2, 2011 | 10:05 PM
Beerthirty86
Ok thanks for the input. Will check wiring and get back with ya asap
