Weird Issue
Old Jul 3, 2011 | 12:05 PM
S S0DEN's Avatar
S S0DEN
Originally Posted by 97tn4x4
The motor pings when under a load.
Correct me if I am wrong, if I power break the vehicle with out letting the wheels spin, it would create that load needed to make the engine ping? The sound does not sound like a ping at all, it sounds like something loose.
Old Jul 3, 2011 | 12:08 PM
S S0DEN's Avatar
S S0DEN
Originally Posted by neilsrpcustoms
The motor is pinging. Try putting in a new ECT (engine coolant temp sensor) and AIT if it still does it after that. The two in combination usually solve any pinging issue.
ECT is a really easy and cheap option, will try that - but what is the AIT?
Old Jul 3, 2011 | 12:15 PM
atthewmartin114's Avatar
atthewmartin114
this is going to sounds stupid but my dakota does the same thing i know its not exhaust and not pinging motor. i checked my transfer case fluid it was low. topped it off and lone behold the noise went away. (being have a have cracked case it leaks back out so it comes back but it was it. under idle its no there under heavy load the chain it tought so it aint there. but mild to light pedel its there.
zman17's Avatar
zman17
Retired Moderator - RIP
It's IAT, Intake Air Temp sensor. May be known at the parts store as Air Charge sensor.
Old Jul 3, 2011 | 12:31 PM
S S0DEN's Avatar
S S0DEN
Got it, pretty easy to find as one will be at the front of the intake, in a water passage and the other must be at the top of the intake in a air passage.
Old Jul 3, 2011 | 12:46 PM
zman17's Avatar
zman17
The ECT is under the alternator and the IAT is on the same side, up higher towards the front on the side of the intake.
A Haynes manual or the FSM download from the FAQ section has the test procedure for all the sensors if you want to test them first.
Old Jul 3, 2011 | 12:55 PM
S S0DEN's Avatar
S S0DEN
Thank you zman, I know where they are. I just did a plenum rebuild and pulled those two sensors already when I cleaned the intake up. I will pick them up at the parts store later this week and see if that resolves the mysterious sound. I do not have much faith in a ping being the sound I hear.
I think it's more of a drivetrain issue from Torque Converter back, but you guys have more experience with these Dodges then I do.
Old Jul 3, 2011 | 01:15 PM
zman17's Avatar
zman17
Neither do I (never know I guess). Noises are the hardest things to diagnose in person, let alone over the internet.
Old Jul 3, 2011 | 01:24 PM
S S0DEN's Avatar
S S0DEN
Can not hear the noise even when applying the break and increasing the RPM's in drive (power break). That should rule out the torque converter, I would think this would be a axle issue, maybe it's time to remove both covers and do a fluid change and see if I can see anything out of place lol.
Old Jul 3, 2011 | 01:26 PM
S S0DEN's Avatar
S S0DEN
What ever it is, it is only while driving and under light throttle so that rules a lot out such as breaks, engine, exhaust, body components ect.
