Weird Issue
Old Jul 5, 2011 | 10:32 PM
  #31
S S0DEN's Avatar
S S0DEN
It's due for a trans service, I really do not want to find out that my 3 year old (NEW) transmission may be junk
But all kidding aside, the pan is being dropped anyways. I really do not want to take it too a trans shop for diagnostic noise issues - they will try to sell me on everything with out actually locating the problem lol.
Old Jul 5, 2011 | 10:38 PM
  #32
Sad, but, unfortunately all to true..... There is only one shop around here I would even consider going to.... all the rest.. well, there answer to everything is "It needs rebuilt"....
Old Jul 6, 2011 | 12:12 AM
  #33
S S0DEN's Avatar
S S0DEN
Dropped the pan and pulled the inspection cover, the pump looks brand new (trans installed 2009) flexplate loogs good from what I can see, and I can not see the torque converter lol.
Here is the pics of what I found in the pan:
Old Jul 6, 2011 | 06:27 AM
  #34
neilsrpcustoms's Avatar
neilsrpcustoms
I doubt, anything is wrong. Even if you could see the converter, it wouldn't tell you anything. unless it's a cracked flex plate.If the converter was bad,you would have a mess in the pan.
Thinking about it some more, it could even be a bad u-joint, if only one single cap is bad, they will click, and until they get really bad, they don't show any play.
Old Jul 6, 2011 | 09:18 AM
  #35
S S0DEN's Avatar
S S0DEN
But a U-Joint would show up weather throughout the entire RPM range, not just at light throttle and stop at half-full throttle. I am hoping the filter was plugged, and the sucking noise I hear, was the pump trying to suck through the filter.
If it was a cracked flex plate, it should show during all engine speeds and not just in a driving condition(30-40MPH).
Old Jul 6, 2011 | 09:19 AM
  #36
S S0DEN's Avatar
S S0DEN
Does the trans filter always look so brown? It has a hard brown substance stuck to the filter.
Old Jul 6, 2011 | 01:10 PM
  #37
S S0DEN's Avatar
S S0DEN
Good news, the transmission is under a 3 year - 100,000 mile warranty from Chrysler (installed 2/11/09).
