Inconsistent starting
Old Jul 3, 2011 | 05:09 PM
tweav88's Avatar
tweav88
Default Inconsistent starting
Okay, so i just got my truck 3 months ago, and i've noticed that normally when i start my truck, it revs to about 1500 rpms and thats when it sounds like it roars to life, but occasionally, when its cold and i go to start it, it sorta grumbles to life and never goes above idle speed, which is around 7-800 rpms.
I posted something about a fuel filter a few days ago, idk if maybe my injectors are getting clogged? i doubt it because it clears up and runs fine, it just starts a little rough, or if it might be a timing issue. and idk if this is even really something i need to worry about, but im paranoid about every little thing that doesnt seem right lol
Thanks for any suggestions, Tweav
Old Jul 3, 2011 | 06:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
As you've probably already figured out, remove the TB and clean it and the IAC . While it's off look ALL around inside the manifold and see if you have oil pooling. Remove the negative battery cable before starting the work.
Old Jul 4, 2011 | 04:09 AM
tweav88's Avatar
tweav88
Okay, ill try that
Old Jul 4, 2011 | 10:55 AM
dhvaughan's Avatar
dhvaughan
normal cold start rpm is about 1000, maybe 900, then a gradual drop to about 600. consistent low rpm or stalling might indicate a clogged port. consistent high rpm might indicate a chunk of crap preventing the pintle from closing.
i'd replace the iac, and clean the well and port in the back of the TB. about $40-50 at any parts store. don't forget to install the o-ring.
keep the old IAC temporarily. if that doesn't fix it, replace TPS. they sort of interact in some mysterious way.
