as previously stated it was as you are sitting behind the steering wheel the mechanic just ****ed up and wrote left side instead of right for brake hardware.
If your replacing one ball joint the others probably have seen some wear. Its going to be a pain so why not just do all of them at the same time, they are like what 8 bucks a pop?
I dont no where they can be found for 8 bucks but the pep boys special they had in stock was $31.
