Ball joint just wont pop. It wont free up Help!
I dont get where Im using a breaker bar or and Impact. If im trying to brake the ball joint lose I use a pickel fork beteween it rite? so where does a breaker bar???? or and impact???? really dont get that
picture of where your at is worth a million words. If your not willing to search this forum for the 2001 dodge ram service manual atleast pop your phone out take a pic and upload it to photobucket and show us.
heres the link for the service manual if you dont have a digital camera
https://dodgeforum.com/forum/2nd-gen...chematics.html
Haha yes. I used the pickle fork because I saw you tube videos that showed to remove the ball joint using a pickle fork. I'm going to work on it today when I get off work at 230.
I already rented one. I watched a you tube video where the guy was saying that you can remove the ball joints using a pickle fork. Would I have messed up my ball joints by trying to pry them out with a pickle fork? The one I poped out with one I had a real bitch of a time pressing it back in. Its almost all the way but not quite seated. I broke 2 craftsman breaker bars and an adapter trying to get it all the way in with the press
Driver side ball joint only. Passanger side I was trying to get the knuckle off so I could replace the hub since the factory service manual from dodge forum says u have to take all that **** off to replace the hub when I could of just pulled the hub out. So now I'm trying to just get the upper ball joint passanger side seated flush and then put in the new hub. Drivers side upper ball joint only.
i see how you get so frustrated now zman. I did this job with the service manual, impact drill, and a ball joint press and the only screw up i had was trying to pop the ball joints on the bottom up cause i thought logically thats how they would put them in. When i started looking at it more carefully i noticed they went down. DOH! change the clamp impact it and BOOM there out. got fed up with the top ones cause couldnt get impact in there so pulled off control arms took it to a press shop in town had em press in new control arm bushings and ball joints for 25 bucks.
