Ball joint just wont pop. It wont free up Help!
#21
i see how you get so frustrated now zman. I did this job with the service manual, impact drill, and a ball joint press and the only screw up i had was trying to pop the ball joints on the bottom up cause i thought logically thats how they would put them in. When i started looking at it more carefully i noticed they went down. DOH! change the clamp impact it and BOOM there out. got fed up with the top ones cause couldnt get impact in there so pulled off control arms took it to a press shop in town had em press in new control arm bushings and ball joints for 25 bucks.
And don't forget he's working on 4x4.
#22
on
Try a blowtorch. I had to heat up my idler arm before it would come free, a little bit of heat and just have to tap the pickle fork with my hammer and it came right out.
I know this question is about Dodge Ram's but my father in law heat to heat up the lower ball joint on his F150 to get them out.
#23
#24
#25
#26
I was able to get both knuckles off today. I couldn't get the lower ball joint off at all on the passanger side. Now onto the ball joint press. My buddy seems to think its to small. I've tryed to use it without any luck. It does seem extremly small. I can't seem to press the ball joints out with it or press them in. Can sort of press in. Just can't press out it just doesn't seem to open enought
#27
I finally did get everything done. I replaced all the ball joints and the wheel bearing. I had alot of problems but it was mainly that I had never used a ball joint press before or done anything like that. I got it all done and I'm going to put a write up on here with pictures and my main problem was pressing the ball joints out and hopefully it will help everyone.
