Engine light on!!!
Old Jul 10, 2011 | 07:20 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default Engine light on!!!
2001 dodge ram , 4x4 , quad cab
Check engine lights on
Code- 40442 Evap leak
Bought a new gas cap
Cleared code
Code came back
Checked gas tank filler neck, looks fine
Check evap canister lines,etc they look fine
Is their any test i can do to check, or any common place that lines goes bad that i can look for?
thanks
Old Jul 10, 2011 | 08:30 PM
dhvaughan's Avatar
dhvaughan
check the rubber vac lines at the purge solenoid on passenger side fender - cut off the split ends.
check the vac lines on top of the cannister and replace.
see here.
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
Old Jul 10, 2011 | 08:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That should be in the FAQ section.
