discontinued auto parts
Old Apr 1, 2020 | 12:21 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by smokeydog
I also have 94 Ram 2500 diesel that my son bought, his first pickup, when he used the headlights the first time that circuit and the dome light/speaker circuit caught fire.
The previous owner made several wiring mods that caused the fire. Can anyone help finding harnesses or connectors? any help or advice would be welcomed.
I've tried replacing the wires in the connector but I can't get the wires out. The videos make it look easy but that's not my reality.
Thank you in advance for any help
You have two options. Get everything from a junkyard or buy a terminal removal tool, buy the terminals for the connector and right colored wire and replace the burnt wires. This option is only good if you the connector isn't damaged
Old Apr 1, 2020 | 12:35 PM
smokeydog's Avatar
smokeydog
Default 94 Ram electrical
That's what I thought, have you had any luck removing the wires from the plug?
Old Apr 1, 2020 | 02:05 PM
With the right tool, its easy. Without it, it's a major pain. If there are trucks in the junkyards around you, I would be real tempted to find one with a good harness, and take the whole thing. 94 or 95 trucks should work.
Old Apr 1, 2020 | 02:21 PM
MoparFanatic21
Yeah that's exactly how I do it. I have a 80 piece terminal set but usually use a really small flat head screwdriver (usually to last to go get the kit ). The pins I get through a website (can link it if you want) and are like $0.03 per pin but have to order at least 20
Old Apr 1, 2020 | 03:11 PM
smokeydog's Avatar
smokeydog
That would be great if I could get that link. Thanks
I'm going to try the flat head screwdriver I'll let you know how it works out
Old Apr 1, 2020 | 06:40 PM
MoparFanatic21
Delcity.com you have to know what kinds of pins the connector takes
Old Apr 13, 2020 | 08:48 AM
smokeydog's Avatar
smokeydog
Thanks everyone for all the help. I kept messing around with the tiny eyeglass screwdrivers and got the pins out.
I do have another question, about the alternator. It appears the former owner changed the alternator from a dual field to a single field.
I think he thought the voltage regulator wasn't working??? So he installed what looks like a regulator on the fire wall and wired it to the Alt.
I plan on replacing it with stock but all the wires have been cut and rerouted. Does anyone know where the field wires go ?
Thank you
Old Apr 13, 2020 | 12:08 PM
MoparFanatic21
Thank you
Field wires should go to the computer. The voltage regulator is built into the computer so if it's bad you either replace the whole computer or put an external voltage regulator on it.
