exhaust smoke
Old Aug 31, 2011 | 12:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd say a compression test is first on the list.
Old Aug 31, 2011 | 01:00 PM
heatonsV10's Avatar
heatonsV10
My cousin is having this problem with his Chevy. He took it in under warranty but they said there was nothing wrong with it.
Old Aug 31, 2011 | 01:22 PM
zman17's Avatar
zman17
Problem solved then. It's all in your head.
Old Aug 31, 2011 | 01:33 PM
SilverSS's Avatar
SilverSS
lol I'm still having the same problem. Never found out why it's burning oil. Plugs still look good. Compression is the same as stated before. It smokes when it sits and idles. There's not a lot of smoke upon initial startup which is what my other cars did when it was the valve seals. I'll probably replace those when I get around to it. Anybody have any idea why the PCV valve would be stuck in the valve cover? It still won't come out. It's a Mopar pcv that's only a few months old.
Old Aug 31, 2011 | 01:45 PM
zman17's Avatar
zman17
The rubber grommet get's hard and brittle. Are you sure you are trying to replace the PCV and not just the breather elbow?
Old Aug 31, 2011 | 03:25 PM
SilverSS's Avatar
SilverSS
Yes just the pcv. I put a purolater pcv in it after I bought it then after reading on here got a mopar pcv. Went right in fine. Took it out once more when I replaced the hose going to it. When I did the plenum it wouldn't come out. Still wont.
Old Aug 31, 2011 | 03:28 PM
zman17's Avatar
zman17
Some times it's easier to remove the whole grommet with the PCV still in it.
Old Aug 31, 2011 | 04:53 PM
kadetklapp's Avatar
kadetklapp
I'd say check your plenum gasket just in case?
Old Aug 31, 2011 | 05:01 PM
zman17's Avatar
zman17
He already fixed that according to his first post in this thread.
