fuel pressure problem 97 ram truck
Old Jul 14, 2005 | 01:06 AM
grainger's Avatar
grainger
Default fuel pressure problem 97 ram truck
I believe that I am having fuel pressure problems and I want to check the pressure at the fuel rails. My (97 dodge ram 360) fuel rail does not have an access port, so I was wanting to split the rubber hose that runs from one fuel rail to the other and put a permanent "T" fitting and fuel gauge on the engine under the hood. Has anyone done this or something similar.
thanks for any ideas and support
Old Jul 31, 2005 | 02:16 AM
grainger's Avatar
grainger
Default RE: fuel pressure problem 97 ram truck
Well I took a gamble and replaced the fuel pump and cured my problem of hard starts.
Old Aug 2, 2005 | 02:26 AM
roadrunner2u's Avatar
roadrunner2u
well my fuel pump is going to. is the easiest way taking the bed off. the reason why is i have half a tank of gas in it. and where is the least expensive place to buy one.
Old Aug 2, 2005 | 01:50 PM
cnewt15's Avatar
cnewt15
Yes, with that much gas in the tank, I would take the bed off. Not hard at all. On mine, there was only 6 bolts, and one ground strap on the pass. side near the front bolt. And you dont even have to set the bed all the way off. If you have a friend and two equal length 2x4's, just lean the bed back like a dump truck, and voila! there is the fuel pump! As far as cheapest, In my neck of the woods, the dealer was about $300, and autozone and advance were more then half that. I think I paid $125 for mine last year.
Old Aug 2, 2005 | 03:48 PM
1500sport's Avatar
1500sport
I was just curious to see that you guys with fuel pump problems, are you running fuel with any ethanol content. I know back in 95 my dad had a v10 and he burned Casey's gas some and at the time I think it was 10% ethanol. He got worse mileage from that gas compared to other pure fuels and had to have the fuel pump replaced in it while still under warranty which meant it had low miles. After that he quit burning the ethanol mixed crap gas and didn't have any more problems. I just wondered if there was a coincidence or not.
Old Aug 3, 2005 | 07:37 PM
roadrunner2u
where did you find the fuel pump that cheap. around here is at about 240. anyways let me know would help out alot.
