Plenum
Old Jul 18, 2011 | 12:40 PM
blakeek00's Avatar
blakeek00
Default Plenum
Would Blown Plenum Gasket cause external oil leak?
It seems to be leaking onto the oil filter.
Old Jul 18, 2011 | 01:49 PM
Ramzy's Avatar
Ramzy
No, plenum is internal but a leaking valve cover or a bad filter mating surface can cause a drip to appear there as well as few other things. Get a drop light, get underneath and on top and have a look. Plenty of room to see and you should spot it.
Old Jul 18, 2011 | 02:13 PM
redheadhunter21's Avatar
redheadhunter21
x2 on valve cover leak, it will drench the back half of the block in due time
Old Jul 18, 2011 | 03:54 PM
blakeek00's Avatar
blakeek00
I think I can see where it is leaking from its just a few inches above the oil filter, but I'm not familiar with what part it would be, It looks like its further down than the valve cover. It would be a hard pic to take but I will try and take a pic..
Old Jul 18, 2011 | 03:58 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Will either of these help?
Old Jul 18, 2011 | 04:55 PM
blakeek00's Avatar
blakeek00
Yea that does help I think it's leaking from the corner that I circled, or its just leaking onto that spot, but thats where it looks like its coming from to me.
Old Jul 18, 2011 | 05:19 PM
redheadhunter21
Reach around the back side of the heads and see if you can feel oil it can draw to that area with a leak from the valve covers or intake, if you can feel oil back there keep reaching till its dry.
