Is it possible my tranny is still good?
Old Jul 19, 2011 | 01:42 PM
mac208x's Avatar
mac208x
Originally Posted by drewactual
slow down dude.. don't go to adjusting bands just yet...
here is where I was going by telling him to jiggle the 8 pin:
he said slow acceleration.. it likely could be starting in second, as it will in limp mode..
he said he had to coax it to shift, which is also indicative of faulty solenoids..
I've had tranny issues w/ solenoids that never kicked a code, it's not unheard of..
OP: start your truck.. manually move your lever to first, foot off brake and go.. when you reach a comfortable speed (in first gear), manually move the lever to second- does it shift? if it does, continue to build speed, and shift it to drive.. did it?
roll to almost a stop.. start to accelerate again.. does it downshift by itself?
you said it was sitting for a year?
I'm thinking the solenoid is clogged up with tranny crap.. which doesn't mean his tranny is toast, it just means he likely needs to either pull and clear the solenoid, or replace it- and swap tranny fluid (no flush!) at the same time..
the previous owner was a dumb *** thats all i can say lol but he did however mention that i should change the filter and put new trans fluid in. Ill see about that 8 pin again later today. Its way to freaking hot outside to do anything >.<
Old Jul 19, 2011 | 01:51 PM
drewactual's Avatar
drewactual
the governor pressure solenoid sips fluid through it when the tranny is pumping, it is high and dry when it isn't.. gunk in a tranny from friction material can set up in it, and disallow good flow.. there is another sensor in there (speed sensor maybe?; I never get the names straight) that suffers the same, and is directly adjacent to the governor solenoid..
anyway, that friction material is somewhat pasty.. if that truck has a good bit of that in them, and it sat for a year, there is a good chance you have effectively glued it up, as it has likely dried up..
try driving it like I said, which takes automatic shifting out of the equation (it would be even better if you could locate and disconnect the 8 pin and drive it the same way).. If it shifts when YOU move the lever, chances are your tranny is serviceable.. but your fluid, filter, and pressure solenoid/speed sensor need swapping..
Old Jul 19, 2011 | 02:02 PM
mac208x's Avatar
mac208x
I see two connectors, one directly attached to the pan looking thing, and second one more to the right side.
Old Jul 19, 2011 | 02:17 PM
mac208x's Avatar
mac208x
ok this is not from my truck but its kinda simillar, i marked the two connectors im talking about
http://imageshack.us/photo/my-images...pdodgeram.png/
Old Jul 19, 2011 | 02:20 PM
drewactual's Avatar
drewactual
forget the 8-pin for the time being, and just see if you can manually shift the tranny like I described..
Old Jul 19, 2011 | 02:31 PM
mac208x's Avatar
mac208x
ok lol, once i get out of work ill do it. and let you know back. oh also i went thru the thread and im guessing you guys miss understood one thing. When i drive the truck normally (below 2k rpm) it shifts good and just sometimes it wont go into the 3rd gear, However if i accelerate little bit more over 2k rpm it wont jump to 2nd or 3rd gear so than i gotta manually change the gears and if i accelerate really hard up to like 50mph the truck stays in 2nd gear, wont jump into 3rd and than 4th gear. Hope that kinda makes a little more sence
Old Jul 19, 2011 | 06:05 PM
mac208x's Avatar
mac208x
Ok so here are my new findings:
The trans rarely shifts back too first gear so i guess that means it stays in 2nd gear. (From a 20 Mile drive it only shifted back twice)
If i put it in 1st gear, than back to drive while being stopped, it will shift too second gear but wont shift too 3rd gear even at low rpm.
And i still cant find that 8 pin i think i need new glasses >.>
Old Jul 19, 2011 | 06:52 PM
drewactual's Avatar
drewactual
go buy a haynes manual for your truck.. it is as indispensable as a wrench when working on them.. you're going to want to seek out somebody other than me, who has a functioning gray matter housing group, and who can recall the floggin' names of those two electronic critters that sit side by side next to your valve body, which is hidden by your pan..
one is the governor pressure solenoid, and the other a floggin _____ speed sensor? errrrr... I'm just passing through right now and can't go look them up for you.. seek out someone like HeyYou, Zman, Unreg, Monte, CAPT, Aim4, VW.. someone who can remember the names..
it is an easy job.. drop pan (prepare to get washed in tranny fluid).. drop filter (replace it).. remove sensors, replace.. reverse order... fill.. an hour of work, about $200 for parts/fluid/new gasket and filter..
You gave it away when you said it was stored, and that it didn't want to go to first by itself.. it's limping.. from what your omitting, I'm guessing it isn't slipping.. that bodes well to avoid a rebuild at the present time..
if you are confident in yourself and your tools, you SHOULD adjust the bands while you're in there.. it's in the manual.. it isn't hard, but it needs to be done right..
IN THE MEANTIME: drive your truck like a manual, using the column shifter.. excess slip (starting in second) works the tranny, and gets things hot.. hot eats clutch surface.. clutch surface gone will necessitate a rebuild.. let's procrastinate on that, shall we? It won't hurt it to be driven as it is so long as you manually shift, but you could burn it up pretty quick if you try to let it do it's own thing.. so, don't..
Old Jul 19, 2011 | 07:07 PM
mac208x's Avatar
mac208x
so im guessing cleaning 8 pin wont work lol, well thanks for your help at least now i know where to start or what to do.
Old Jul 20, 2011 | 12:28 PM
mac208x's Avatar
mac208x
Ok so im making a list of what i will need let me know if this is correct:
Trans Fluid
Trans Filter
Governor Pressure Solenoid
Gasket
The other Sensor thingy
Anything else?
