1/4 mile times and mods
Old Jul 19, 2011 | 12:05 AM
DodgeRam5.9's Avatar
DodgeRam5.9
Default 1/4 mile times and mods
Well I kind of have 2 questions here really 1st question is what kind of 1/4 mile times are you 2nd gen guys running and with what mods...2nd question is what are some estimates for what my truck might run I havent gotten to the track yet and I'm not very good at estimating these things...my mods are rebuilt 360, mild Hughes cam, Hughes 1.65 shaft mount roller rocker kit, shorty headers and 3in true dual exhaust, 4.11 gears, 28in drag radials for the track, SCT tuner, kb flat top pistons with reliefs (10.3comp ratio) and I will be getting a Hughes air gap intake, and a 4bbl throttle body prior to hitting the track
Old Jul 19, 2011 | 02:48 AM
99dodge318's Avatar
99dodge318
theres a member on this site named rm-indy, google his name and dodge forum together.
Old Jul 19, 2011 | 06:24 AM
4085spd's Avatar
4085spd
Spec's on cam? What head's u running? x2 RM-INDY will be your only hope.
Old Jul 19, 2011 | 08:05 AM
Adobedude's Avatar
Adobedude
Hopefully you upgraded your valve springs if you're still on stock heads, why the 4bbl throttle body? Go with a big F&B 2bbl like a 55x52 or a 58 and save a ton of install time, they simply bolt on, won't have to rewire sensors or fab a throttle bracket like you will with a 4bbl.
Old Jul 19, 2011 | 03:21 PM
DodgeRam5.9
Valve springs have been replaced along with the retainers...cam specs Are 208/214@.50 lift, 512/520 lift 114lsa the reason for going with a 4bbl TB is that I can get a used one from a freind for 200$
