2wd off roading
Old Jul 23, 2011 | 03:20 PM
  #21
chadhager03's Avatar
chadhager03
At least 8000 pounds, the more the better though
Old Jul 23, 2011 | 03:33 PM
  #22
Winch should be rated for one and a half times your vehicle weight, at least. More is better, and there is no such thing as too much. (within reason.... you don't need a 60 ton crane to follow you around..... but, if you had one, you would never have to worry about being stuck.......)
Old Jul 24, 2011 | 10:37 AM
  #23
newman1367's Avatar
newman1367
The BEST solution would be a selectable locker (ARB, Ected, etc.) because it's an open diff when you want it to be and fully locked when you flip a switch. But it's also the most expensive.
There's not a selectable locker for the Chrysler 9.25 rear.
Old Jul 24, 2011 | 12:42 PM
  #24
HammerZ71's Avatar
HammerZ71
Another moderator and I talked at length to an Auburn rep at a 4x4 show this spring who said the Ected was in the works for the 9.25" AAM axle, that it was planned for last year but they moved support for the 10.5" AAM up ahead because GM is now using that axle in their 3/4 tons in addition to the 3/4 ton Rams. They said look for a release 4th quarter of this year or 1st Quarter next year.
The ARB guy also said plans were in the works but had no idea when it would hit the market...
Old Jul 24, 2011 | 04:36 PM
  #25
newman1367's Avatar
newman1367
The 9.25 AAM axle is for the front, won't work for the Chrysler 9.25 rear.
Old Jul 25, 2011 | 11:26 PM
  #26
Josh127's Avatar
Josh127
hey dupe what kind of lift kit do you have on your dodge ram 1500 2wd because im looking for a lift kit for my 99 dodge ram 1500 2wd and im having no luck whats so ever. i found this website http://app.infopia.com/Shop/Control/...112/rid/127794 tell me what you think. thank oyou
Old Jul 26, 2011 | 02:44 AM
  #27
redheadhunter21's Avatar
redheadhunter21
Doetsch tech has lifts for our trucks, also ebay has them, canuck motorsports is the brand.
