replacing carpet
Old Jul 19, 2011 | 08:27 PM
sullivanj04's Avatar
sullivanj04
Default replacing carpet
What's the cheapest way to replace the carpet mine is nasty
Old Jul 19, 2011 | 08:45 PM
Rubber mat.
You can find stock replacement carpet, but, it runs a couple hundred or so.
Old Jul 19, 2011 | 08:46 PM
96magnumram's Avatar
96magnumram
Go on ebay and get a molded carpet from there...it will run around $130 and up
Old Aug 5, 2011 | 09:52 AM
whatman27's Avatar
whatman27
Or u can pull it out, clean the crap out of it and im clean that thing like youve nvr cleaned anything before lol then dye it back to OEM color or use the plastic, vinyl and Capet spray that the local autoparts store should carry. im pretty sure it will look decent after. and it wont smell anymore
Old Aug 5, 2011 | 11:39 AM
gipperkid's Avatar
gipperkid
Go to www.accmats.com. Get the part number for the carpet that fits your cab. Then go to www.partstrain.com and search with the part number. They have the cheapest price. The ACC carpet is good quality too. I have used it in two Dodge Rams. I have aslo used Nifty Pro-Line, but is a bit more expensive. I got replacement carpet for my 2000 QC for $143.
Old Aug 5, 2011 | 11:43 AM
Agostage's Avatar
Agostage
I was thinking the same thing, but I ended up using a series of rust and dirt removal carpet sprays and a wet vac and it turned out pretty decent. These carpets can actually take a pretty good beating and be cleaned if you're willing to work it a bit.
